b2: Line returns are incorrect IPTC write
marsh
Metadata>Edit IPTC data>Write in viewer doesn't handle line returns correctly. Null String (odd characters) displayed between words instead.
Re: b2: Line returns are incorrect IPTC write
You means if you use CR in IPTC field, they don't appear in labels of thumbnail view?marsh wrote:Metadata>Edit IPTC data>Write in viewer doesn't handle line returns correctly. Null String (odd characters) displayed between words instead.
marsh
Result in Tab>IPTC>Caption is incorrect.xnview wrote:You means if you use CR in IPTC field, they don't appear in labels of thumbnail view?marsh wrote:Metadata>Edit IPTC data>Write in viewer doesn't handle line returns correctly. Null String (odd characters) displayed between words instead.
Strange, i see only space, so i change CR to spacemarsh wrote:Result in Tab>IPTC>Caption is incorrect.xnview wrote:You means if you use CR in IPTC field, they don't appear in labels of thumbnail view?marsh wrote:Metadata>Edit IPTC data>Write in viewer doesn't handle line returns correctly. Null String (odd characters) displayed between words instead.
