In the setting of the Batch Scanning (File > Acquire into...) there's options to build the filename. Rather than having special options I'd like to see the standard placeholders known from Batch Rename insertable (e.g., <Current date>).
XnView 1.82.4 and 1.90 b2.
Batch scanning: Standard placeholders in filename
Re: Batch scanning: Standard placeholders in filename
Right will be betterhelmut wrote:In the setting of the Batch Scanning (File > Acquire into...) there's options to build the filename. Rather than having special options I'd like to see the standard placeholders known from Batch Rename insertable (e.g., <Current date>).
buckaroos88
I'm needing a "batch scanning" filename that has the incrementing number in the MIDDLE of the filename not the LAST part of the name before the ".jpg". What I want is similar to the following example:
"foobar 0001 suffix-goes-here.jpg"
where I specify the "foobar" and "suffix-goes-here" but XnView inserts the incrementing number.
Is this possible?
Best regards!
Is this possible?
Best regards!
Sorry not possible currently...buckaroos88 wrote: Is this possible?
