All these options works good in Folder tree, but doesn't work in Favourites 'tree':
- Single click to expand f.t.
- Auto collapse
- Single clic to rename (always enabled)
I'm not sure if it's a bug, since it's not a "folder tree", but it should work the same IMO.
V1.90 B3
Favourites 'tree' - some options don't work
Dreamer
Re: B3: Favourites 'tree' - some options don't work
Ok, i fix the 'single clic to rename', but have some problem for 2 others option in favorites... So for a later version...Dreamer wrote:All these options works good in Folder tree, but doesn't work in Favourites 'tree':
- Auto collapse
Dreamer
