Context menu not updated: Remove from this category
When viewing categories and the right clicking on an image, one can see the menu items "Remove from this category" and "Remove from all categories". Correct.
When switching back to the folder tree and then right clicking on the same image, you will still see the context menu with items "Remove from this category" and "Remove from all categories". Not o.k. :bug:
V1.90 B3
ckit
Post by ckit »
Confirmed.
The other files and folders in that folder do not appear until you click on another folder and then return to the original folder.
ckit wrote:The other files and folders in that folder do not appear until you click on another folder and then return to the original folder.
It will also update once you click on the current folder for a second time.
I think this is more or less normal behaviour, since you might want to an operation with the shown file. If you would show the contents of the folder immediately, no such operations would be possible.
Re: B3: Context menu not updated: Remove from this category
helmut wrote:When viewing categories and the right clicking on an image, one can see the menu items "Remove from this category" and "Remove from all categories". Correct.
For me, i add always this entry, it's not necessary to be on tree categories to be able to remove categories for a file!
xnview wrote:For me, i add always this entry, it's not necessary to be on tree categories to be able to remove categories for a file!
This is not the behaviour I experience in Beta 3:
I have images with ratings and categories but the menu items "Remove from this category" and "Remove from all categories" only appear when switching to "Categories" and selecting a category. I think this is correct and even needed, otherwise how would you not which category to remove from?
Ok, right. But when you switch tree, you are always in the result for category, not a result for folder tree, so it's normal that you have always this entry...
