B3 - Highlight to dark
Troken
Post by Troken »
In B3 the behaviour of options-dialog has changed. If you open options and navigate through the left options list, first time you select one of the options in the list, the higlight appears darker than usual. Second time it becomes normal again, just as in previous versions. Strange huh?
1. click "options"
2. select one of the choises in the left list
3. the highlight is darker than usual.
4. click another one (still dark)
5. click on the first one again. Now the highlight is normally coloured.
ckit
Post by ckit »
Confirmed, this is a bug.
Already reported
—> Troken
:) Hello !
• Already reported HERE, it's the same issue… :wink:
:mrgreen: KR
Troken
Post by Troken »
OK, thanks Clo!
Feel free to close or remove this thread then.
ckit
Post by ckit »
There are still problems with this in Beta 4, dark grey is no longer an issue though.
ckit wrote:There are still problems with this in Beta 4, dark grey is no longer an issue though.
Which problems?
ckit
Post by ckit »
Click on anything on the left in options and the select colour only flashes once and then disappears. This happens 90% of the time.
Troken
Post by Troken »
Confirmed. Not as dark as B3 anymore though. It's like a slightly different grey.
ckit wrote:Click on anything on the left in options and the select colour only flashes once and then disappears. This happens 90% of the time.
Ok, yes when you select an item, the focus is removed, i don't know why...
Olivier_G
Post by Olivier_G »
-> confirmed.
Yes, whenever clicking a category for the very first time this problem can be seen. Perhaps it has to do with object instantiation. Try navigating the categories with the cursor keys and you will experience another, probably related problem: Using cursor up/down you can only navigate inbetween categories which you have opened, already.
Olivier_G
Post by Olivier_G »
helmut wrote:Yes, whenever clicking a category for the very first time this problem can be seen.
I confirm this behaviour here too...
Olivier
Olivier_G
Post by Olivier_G »
Fixed in Beta 6.
Can someone else confirm, before closing (as we are not in a 'fixed' area)?
Olivier
Readable
—> Olivier_G
:) Hi !
• I can confirm “Fixed up” here with ß-6…
:mrgreen: KR
Olivier_G
Post by Olivier_G »
Thank you, Claude.
