Remove from category does not work
Adding images to categories and ratings works very well. But removing doesn't.
1.) Open browser
2.) Drag an image on the category tab (the categories will open then) and drop it on Colour label "Important".
--> The image is assigned to this category, now. (Correct)
3.) Right-click on image and choose "Remove from this category".
--> The image is not removed from "Important". :bug:
V 1.90 B3
OK here
:) Hi !
• I cannot confirm, I tested this and it works for me…
:mrgreen: G.
Re: OK here
Clo wrote:• I cannot confirm, I tested this and it works for me…
Thank you, Clo, for your immediate feedback.
Have you tried with "Colour labels" (e.g. "Important")?
Fine too
:) Yes, I tested to remove from "Important" where I have put a file, it works fine too…
:mrgreen: G.
Re: Fine too
Clo wrote::) Yes, I tested to remove from "Important" where I have put a file, it works fine too…
Hmm, strange. I cannot remove any image from the "Colour labels". When selecting "Remove from this category" all images dissappear (shock :shock:), but when clicking on category "Important" they **all** appear, again.
Comes back
:) Ah ! It's removed on the moment, but it comes back when closing¦restarting !
So, there is a :bug: , right.
:mrgreen: G.
Re: Comes back
Clo wrote::) Ah ! It's removed on the moment, but it comes back when closing¦restarting !
That's what I mean. Restarting or clicking on the category, again, will show the problem. Thank you for reproducing and confirming, Clo. :-)
Re: B3: Remove from category does not work
helmut wrote:Adding images to categories and ratings works very well. But removing doesn't.
1.) Open browser
Rating and colour label are not category!!
Re: Fine too
If you click on a category with 2 files, you select one, and use 'remove from category', so this picture is removed from the list. If you have 1 picture, you have no more file... It's normal!
Re: Fine too
xnview wrote:If you click on a category with 2 files, you select one, and use 'remove from category', so this picture is removed from the list. If you have 1 picture, you have no more file... It's normal!
O.k., removing from "real" categories works o.k..
Categories, Ratings, and Colour labels are all listed in one tree, so I'd expect this to work all the same. How do I remove an image from "Rating" or "Colour label" using the context menu? Will there be two more menu items "Remove from this rating" and "Remove from this colour label"? I'd find one menu item for all types (Categories, Ratings, and Colour labels) simpler.
-> Info & Feedback
Re: Fine too
-> Info & Feedback
Currently, you have menu and ALT+num or CTRL+ALT+num
marsh
Re: Fine too
Post by marsh »
-> Info & Feedback
Remove from this database ?
Remove from all databases ?
(This naming should be familiar since it is already used in options.)
Otherwise, current unused menu items could be greyed out to avoid confusion.
marsh
Post by marsh »
I think unused menu items were removed to avoid confusion.
--->Resolved.
Petran
Post by Petran »
I was looking for this also, but I can't find the menu. What do I miss? Where is that menu situated?
regards,
Petran
Aldi
Remove from Rating
Post by Aldi »
To remove from ratings & colour labels: select the image, from the top menu choose view>rating & colour lable, then select unrated or unlabeled
