When using the search for similar files, there's a progress bar in the dialog but the progress bar does not progres.
1.) Tools > Find similar files...
2.) Start a search for files with same file name (default)
--> Progress bar will not move a bit until the whole search has finished.
XnView 1.90 <x>
Find similar: Progress bar does not progress
Re: B3: Find similar: Progress bar does not progress
It's not really a bug, i use this progress bar for the similarity search not files.. So please postponed, i'll change that...helmut wrote:When using the search for similar files, there's a progress bar in the dialog but the progress bar does not progres.
No problem. You can postpone whatever you like - you are the bossxnview wrote:It's not really a bug, i use this progress bar for the similarity search not files.. So please postponed, i'll change that...
-> Postponed.
