B3: "Forward" symbol a bit broken
In XnView 1.90 there are two symbols < > in the "small" toolbar of the browser for viewing the previous/next folder in history. The "Next" symbol is a bit broken, it has two dots on the left side which shouldn't be there.
1.) Browse a folder
2.) Use "Back" symbol "<" for browsing the previously browsed folder.
--> The "Forward" symbol is active. One can well see the wrong pixels in the symbol.
Default ?
:) Hi !
• I suppose you mean using the default skin ?
• Here, I use a skin of mine, and there is no problem, the display is OK.
- It could be a defect on the default small tool-bar skin, I go to check this (if possible…)
:mrgreen: G.
Re: Default ?
Clo wrote:• I suppose you mean using the default skin ?
Right, the defect is in the default skin.
I corrected, but…
:) Yes, I compared with my own bitmap, the default skin has these two symbols badly located on the bitmap…
- So, you see a small part of the other symbol as "two dots"…
:mrgreen: G.
Re: I corrected, but…
Clo wrote::) Yes, I compared with my own bitmap, the default skin has these two symbols badly located on the bitmap…
- So, you see a small part of the other symbol as "two dots".
Thanks for checking, Clo. -> Confirmed
Still broken in Beta 4.
Back to -> Confirmed
ckit
Post by ckit »
This must be Fixed in Beta 5, I don't see any dots :)
