gflSaveBitmap 16 bit Tiff to DPX
jjIVC
Post by jjIVC »
Love the SDK. Thanks for giving us Visual Basic guys something to work with.
I am trying to convert 16 bit Tiff files to 10 bit DPX, but every time the dpx comes out bad (will not read in anything, even xnview). Conversions using 8 bit files work fine. Is there something extra that needs to be done with 16 bit files?
Thanks
Re: gflSaveBitmap 16 bit Tiff to DPX
jjIVC wrote:Love the SDK. Thanks for giving us Visual Basic guys something to work with.
How do you use it? Do you use GFL LUT to convert in 10bits?
jjIVC
Post by jjIVC »
No, I'm loading the 16 bit Tiff using GFL_LOAD_ORIGINAL_DEPTH and saving to DPX format. Do I need to use an external LUT, and if so is there a description of the format?
jjIVC wrote:No, I'm loading the 16 bit Tiff using GFL_LOAD_ORIGINAL_DEPTH and saving to DPX format. Do I need to use an external LUT, and if so is there a description of the format?
Wait the new release, perhaps an old bug.
