I was curious about the permanence of favorites and categories, so I tried renaming and moving files around folders; none updated. I'm hoping that it could process the file's categories when renamed/moved to keep in sync, and process a folder's favorite status. When doing such administration from outside xnview, I doubt there's any elegant way to work it.
Haven't tried B4 yet, will soon. (Although it seems to be more unstable than usual for most.)
V 1.90 B3
Rename doesn't carry to favorites and categories
foxyshadis
Re: B3: Rename doesn't carry to favorites and categories
Yes, currently there is no synchro between folder on disk, and folder in the database.foxyshadis wrote:I was curious about the permanence of favorites and categories, so I tried renaming and moving files around folders; none updated. I'm hoping that it could process the file's categories when renamed/moved to keep in sync, and process a folder's favorite status. When doing such administration from outside xnview, I doubt there's any elegant way to work it.
