Preview pane - Properties tab suggestions
Dreamer
Post by Dreamer »
1. If the filename is too long, horizontal scrollbar is shown always, perhaps it could be shorten to pane width automatically - or/and - columns could be manualy changeable - as file list in Details view.
2. Image/Audio/Video info is more important than basic File info IMHO, so I suggest to show this info first, then File info - or/and - if I collapse File info (click the [-] button next to File), save it also if xnview is closed/restarted.
XnView 1.90 <x>
Dreamer
Olivier_G
Re: Preview pane - Properties tab suggestions
Post by Olivier_G »
Dreamer wrote:2. Image/Audio/Video info is more important than basic File info IMHO, so I suggest to show this info first, then File info - or/and - if I collapse File info (click the [-] button next to File), save it also if xnview is closed/restarted.
I am not that sure about File vs Image/Audio/Video importance... :? ...The advantage of having File info first is that layout is more fixed when changing filetype (=easier to spot).
But I support your idea to remember collapsed/expanded state for Info (I would love it for EXIF).
Olivier
Danny
Post by Danny »
Personally, i would like to be able to position the preview and properties areas above each other. Especially for the 3 vertical columns layout - which i am using when i have 2 monitors at my disposal.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Olivier_G
Post by Olivier_G »
Danny wrote:Personally, i would like to be able to position the preview and properties areas above each other.
I think you are asking for what has been requested here.
Olivier
Olivier_G
Post by Olivier_G »
Olivier_G wrote:But I support your idea to remember collapsed/expanded state for Info (I would love it for EXIF).
This part has been implemented in Beta 6... :D
Olivier
