[Wish] Copy name¦s to Clipboard…
:arrow: Pierre
:) Hello !
• Indeed we have the File listing, but this is not handy and needs :
1. To be in Browser mode,
2. To fill out entries in a dialogue in which the most ones are useless the most times.
3. To create a text-file, so one can't paste directly a file-name elsewhere when needed…
• The Listing thingy is no more available in View mode, and I miss commands (let's say, for 1…3 buttons) allowing to simply copy the current file-name into the Clipboard…
- So, I ought make this in Total Commander, that breaks the workflow… :|
- In that programme, we have the following commands to do so :
cm_CopyNamesToClip —> Copies the current file-name¦s into the Clipboard.
cm_CopyFullNamesToClip —> Copies the current file-name¦s plus the full path¦s into the Clipboard.
cm_CopyNetNamesToClip —> Same for a Network path.
- There are others about Source¦Target, but useless here.
- The most missing being of course cm_CopyNamesToClip to use for a single current file in View
• Please, could you consider this wish ?
:mrgreen: KR
XnView 1.90 <x>
ouistiti
Post by ouistiti »
:arrow: Clo
I support
Paul
1,77245385090552...
TX !
:) Hello !
• Thank you Paul, it could be very useful !
• Yep ! “2000” !
:mrgreen: Friendly,
ouistiti
Post by ouistiti »
:arrow: Clo
Congratulation for your [2000] :D
Paul
1,77245385090552...
ckit
Re: TX !
Post by ckit »
Clo wrote::) Hello !
• Yep ! “2000” !
:mrgreen: Friendly,
Congrats, Clo :)
TX to All !
:D Thanks to All !
• The next goal is "3000", I'll try to live long enough to reach it ! Image
:mrgreen: KR
Congratulations, Clo! If you continue like this we will see your 10.000th post one day. ;-)
marsh
Re: TX !
Post by marsh »
Clo wrote: • Yep ! “2000” !
Thanks for the many colorful posts. :)
Olivier_G
Post by Olivier_G »
Happy 2000, Claude!!!
I tried a colorless version... :mrgreen:
ckit
Post by ckit »
LMAO, you guys are priceless :)
Topic ?
:D Well ! Thanks again to everybody !
• But now, what about the topic ? :wink:
:mrgreen: KR
ckit
Post by ckit »
I support your request as long as it's in the Edit menu.
Toolbar buttons would be a waste for Clipboard functions.
Extra-buttons…
—> ckit
:) Hi !
• Thanks !
- But when I say "buttons", I don't mean by default ! I mean buttons one can add now using extra-icons
(that are not provided yet… except some I made for tests).
- Each user can add any button s¦he needs, can't him¦her not ?
- So, only internal commands are missing, in the same painting than those of TC I show above…
:mrgreen: KR
ouistiti
Post by ouistiti »
:arrow: XnView
Pierre, please ?
We would be happy to find this hung at our X-Mas trees :D
Friendly,
Paul
1,77245385090552...
In Browser mode, when using "Edit > Copy" path and filename of the files is copied to the clipboard. You can then paste these into a new text file, for example.
Perhaps the same could happen when using "Edit > Copy" in view mode: The clipboard can contain multiple contents of different types, i.e. image data and a string. So when using "Edit > Copy" the filename could be copied to the clipboard (in addition to the image contents).
From my point of view this would be consistent.
