The defined Keywords list, part of 'Edith IPTC data', stays empty although keywords have been added. How do I proceed to establish a list of used keywords. Also, is that list related only to the selected jpg-file, or should it represent all keywords used so far for any file.
Thank you
Hans
IPTC - defined Keywords list
Re: IPTC - defined Keywords list
This list is used for every IPTC editing, you can add keywords to this list to use it after...hansi wrote:The defined Keywords list, part of 'Edith IPTC data', stays empty although keywords have been added. How do I proceed to establish a list of used keywords. Also, is that list related only to the selected jpg-file, or should it represent all keywords used so far for any file.
hansi
IPTC - Keywords list
Thank you for your reply.
I already added keywords and finished with "write", but nevertheless this Keywords list remains empty. Am I missing something?
Thanks
Hans
Thanks
Hans
Re: IPTC - Keywords list
As i tell you, the list is saved to be used for another IPTC editing!hansi wrote:Thank you for your reply.
Else you have popup menu to clear it
