Batch Rename
PeterF
Batch Rename
Post by PeterF »
<Moderator's note: This topic has been moved>
It would be good to be able to include the existing filename as part of the new name
Re: Batch Rename
PeterF wrote: It would be good to be able to include the existing filename as part of the new name
You can by using <Filename> or popup menu
