B5: similarity delete makes empty filename in recycle bin
foxyshadis
Post by foxyshadis »
Basically what the title says. The files show up in the recycle bin with an icon, no filename, and the folder listed with the doubled slashes (related to the other bug, not important for this).
Re: B4: similarity delete makes empty filename in recycle bi
foxyshadis wrote:Basically what the title says. The files show up in the recycle bin with an icon, no filename, and the folder listed with the doubled slashes (related to the other bug, not important for this).
Sorry but i don't understand the problem??
foxyshadis
In the search for similar files, find something you don't need and delete one or more files. You'll end up with something like: http://foxyshadis.slightlydark.com/random/recycle.png
Delete to recycle bin has to be on, but confirm can be on or off. (Didn't ask for a confirmation with it on, though.) Restoring the file restores the correct filename as well. Deleting in the browser does not cause this.
foxyshadis wrote:In the search for similar files, find something you don't need and delete one or more files. You'll end up with something like: http://foxyshadis.slightlydark.com/random/recycle.png
Ok, it's funny :-)
Could you test with B5?
foxyshadis
Same behavior in B5.
foxyshadis wrote:Same behavior in B5.
I've tested on 2K and Xp, and have not this problem!
Olivier_G
Post by Olivier_G »
I don't have this issue (Filename is always shown in my recycle bin).
But I found that when you delete a file with Similarity tool, it always end in the recycle-bin... even when Options>'Delete to recycle bin' is unchecked. :bug:
Olivier
foxyshadis
The issue I originally posted about doesn't occur in B6 anymore.
Olivier_G
Post by Olivier_G »
Olivier_G wrote:But I found that when you delete a file with Similarity tool, it always end in the recycle-bin... even when Options>'Delete to recycle bin' is unchecked. :bug:
Solved: 'Recycle bin' setting correctly taken into account with Beta 6.
-> Closed.
Olivier
