When "Confirm file delete" is not checked and "Go to next image when deleting current" is checked and the last image in a folder is deleted, XnView keeps displaying the deleted image. I would have expected XnView to display nothing, i.e. a gray background, just as if the viewer had been started without any files. Otherwise you get no feeback that the file has been deleted in this case, which is not good I think.
V1.90 B5
Deleting last image in folder
Olivier_G
eyebex
Right---
—> eyebex
Hello !
• I confirm, you are right in the conditions you say.
- However, this is not new, since I can get the same issue in the 1.8x versions as well… Ctrl+R displays an error message.
- IMHO, XnView might look at the Recycle Bin before, and whether the deleted file is there,
it might display a special message…
KR
eyebex
Re: Right---
You're right, 1.8x behaves the same.Clo wrote:- However, this is not new, since I can get the same issue in the 1.8x versions as well… Ctrl+R displays an error message.
I guess looking at the Recycle Bin is too complicated. It's easier to find out that there are no more images in the current folder (and then display no image).Clo wrote:- IMHO, XnView might look at the Recycle Bin before, and whether the deleted file is there, it might display a special message…
Re: B5: Deleting last image in folder
Yes, but to have a black screen is not good tooeyebex wrote:When "Confirm file delete" is not checked and "Go to next image when deleting current" is checked and the last image in a folder is deleted, XnView keeps displaying the deleted image. I would have expected XnView to display nothing, i.e. a gray background, just as if the viewer had been started without any files. Otherwise you get no feeback that the file has been deleted in this case, which is not good I think.
eyebex
