Favourites - Context menu: New subfolder
I'm still not 100% happy with the context menu of the favourites. Currently it is:
Delete favourite
Rename favourite
New subfolder
Edit entry...
Add entry...
Sort entries
I'd suggest something like:
New...
Delete
Rename
Edit...
New Folder
Sort entries
I'm tired and have to go to bed, so no explanation why each single change has been made.
V 1.90 B5
Re: B5: Favourites - Context menu: New subfolder
helmut wrote:I'm still not 100% happy with the context menu of the favourites. Currently it is:
Delete favourite
Rename favourite
New subfolder
Edit entry...
Add entry...
Sort entries
New...
Delete
Rename
Edit...
New Folder
Sort entries
I've already change from 'delete' to 'delete favorite' (there is a thread about that) because it's not a delete of folder!
Olivier_G
Post by Olivier_G »
xnview wrote:I've already change from 'delete' to 'delete favorite' (there is a thread about that) because it's not a delete of folder!
The thread.
My vote:
Add favourite
Remove favourite
Rename favourite
Edit favourite
New folder
Sort
I prefer "remove" to "delete" here. I think adding "favourite" may avoid some confusion with actual folder deletion... :?
Olivier
Dreamer
Post by Dreamer »
I agree with Olivier, as I said, I'd prefer the same term (favourite), not "favourite" and "entry", also "remove" would be clearer as "delete", since no real folder is deleted.
Dreamer
Olivier_G wrote:My vote:
Add favourite
Remove favourite
Rename favourite
Edit favourite
New folder
Sort
The user works in Favourite pane, so I think he/she should expect favourites to be deleted. So I think there's no need for adding "favourite". And real folders cannot be deleted, here, so I see no danger.
(In Beta 5 you seem to delete folders by pressing "Del" key, but that's a severe bug and luckily only the entry is deleted, not the real folder).
I don't like "Add favourite" since you actually *create* a new favourite. So why not call it "New.."? (In MS Explorer you don't add folders, either, you create them using "New > Folder").
The above said also applies to "Remove": You delete a favourite and it will be gone, why not name it "Delete" just like everywhere in other applications?
Until now I stick to my menu structure and naming mentioned above.
foxyshadis
Post by foxyshadis »
Add As Favorite, perhaps.
Why I'm thinking it should include 'favorite': This could be quickly added as a submenu in the file browser, where there is no context; and even if you were willing to have two different versions, then you lose the imho very important consistency between them. On the other hand, only add and remove actually make sense when working with the browser, so maybe you're right.
Dreamer
Post by Dreamer »
It looks as folder tree, it's at the same place, there are even real sub-folders (not favorites), just few reasons to include "favourites".
In other applications favorites don't look like folders and there are no real subfolders between favorites - and also there is a possibility to "delete favorite" AND "delete a file on disk" (in some cases, quite often).
Therefore I still think it might be (very) confusing and "favourite" is needed.
Dreamer
marsh
Post by marsh »
M1
Add Favourite
Add Folder
Remove
Sort
Edit Favourite
Rename
M2
Add Favourite
Edit Favourite
New Folder
Remove
Sort
Rename
A DLL…
—> marsh
:) Hello B. !
• Waiting for these mythical text language-files,
you might request an English language DLL in which you could modify¦correct such details at will ;)
• I think that with his programming tools, it isn't a long job to do for Pierre 8)
:mrgreen: FR
marsh
Post by marsh »
In B6, the current menu is has several translation errors. These should be fixed, no matter what order is decided upon.
1. 'Delete favourite' & 'Rename favourite' are mistaken, because they also apply to folders.
2. 'Add entry' is mistaken because it only applies to favourites.
3. 'New Subfolder' is mistaken because it can be a parent folder.
4. The word 'entry' is not needed at all.
Person, not object
:) Hello B. !
• AFAIK, the word "Favourite" as a noun stands for a person, same in French, thus it's wrongly used here.
- As an adjective, it needs an object to define, of course !
1. So, we might have "Favourite folders" etc.
2. Add a new fav. folder ? Or so…
3. Hum… Yes and no… Anyway, it'll be always a sub-folder of its drive :P
- Seriously : "Add a new favourite folder" ?
4. “Entry” is often used as “Menu item”… I suppose it stands for :
"Add this new fav. folder on the menu as a new item " (Yep ! A bit long ! :D )
• Talking of wording and languages, did you see THAT “BUMP” ? ;)
:mrgreen: KR
marsh
Post by marsh »
Clo wrote::) Hello B. !
Hi Claude,
In English, it is often used as an object/noun- but perhaps not in French. So it might look odd to a non-native speaker accustomed to different rules.
Clo wrote: • Talking of wording and languages, did you see THAT “BUMP” ? ;)
Yes! :) That should help with awkward topics like this- adjust it ourselves and forget about it.
marsh wrote: 1. 'Delete favourite' & 'Rename favourite' are mistaken, because they also apply to folders.
Here you delete or rename the favorite folder, not the folder...
'Add new favorite'?
Sorry but i don't understand
marsh
Post by marsh »
I agree. I think of "favourite" and "folder" as seperate items. Folder used in context of this menu, of course. When a command applies to either item, I don't think it is necessary to have another word added to it.
'Add new favorite'?
That would also work well. As would "add favorite", "new favorite".
I always think of a subfolder as something which is secondary to another folder in depth/level. I guess the name could help distinguish it from other types of folders, but I have never seen the word used that way.
