B3: Explorer crashes on showing context menu for .CR2 file
kx
Post by kx »
XnView beta 1/3, option "Use XnView Shell Extension" is checked. When I right click on a file with .CR2 (Canon RAW) extension, Explorer crashes and shows error message with the following details:
"AppName: explorer.exe AppVer: 6.0.2900.2180 ModName: xnviewshellext.dll
ModVer: 1.4.0.0 Offset: 000a32c7"
Also I cann't delete (using keyboard) or cut/copy .CR2 files because of this error. It was not observed in previous 1.82.4 version however.
Re: B3: Explorer crashes on showing context menu for .CR2 fi
kx wrote:XnView beta 1/3, option "Use XnView Shell Extension" is checked. When I right click on a file with .CR2 (Canon RAW) extension, Explorer crashes and shows error message with the following details:
And Xnview doesn't crash when you load it?
kx
Post by kx »
xnview wrote:And Xnview doesn't crash when you load it?
No, it doesn't.
No, it doesn't.
Could you send me the CR2?
kx
Post by kx »
xnview wrote:Could you send me the CR2?
Sure. I've sent.
Sure. I've sent.
On xnview.com??
kx
Post by kx »
xnview wrote:On xnview.com??
Yes. To webmaster.
The message size is about 15 MB.
ckit
Post by ckit »
I recommend re-doing it with 7-Zip, 10mb is usually the largest attachment size you can use.
Split
—> kx
:) Hello !
• ckit is right, 10 MiB is the max. If you can't make the archive smaller than this fateful size, you could split it into two fractions, then send the fractions one by one, each with an email.
• Then it's not complicated to join the fractions to get the whole archive.
:mrgreen: KR
Yes. To webmaster.
I've not received it :-(
kx
Post by kx »
ckit, Clo
Thanks. I believed that larger maximum size of message is allowed on xnview.com.
I'll try to re-send it in three volumes of RAR archive...
kx
Post by kx »
Done.
kx
Post by kx »
Great, shell extension in B6 works fine with .CR2! But now if "Half size" or "Full size" is selected for RAW, XnView crashes on .CR2 open:
"AppName: xnview.exe AppVer: 1.90.0.0 ModName: xnview.exe
ModVer: 1.90.0.0 Offset: 0009351c"
It's a little strange, considering that preview of .CR2 works properly in the browser (with "Half size" or "Full size" selected for RAW preview). It's not significant to me, because I use "Embedded Thumbnail" setting. But for other people it may be annoying bug.
kx
1.90 Release Candidate 1
Post by kx »
The problem has been eliminated in RC1. Now everything works as it should. I like this version. Thanks!
