nconvert ignores the first file / processing directory
asi
Post by asi »
I´m processing multiple Files with this nconvert command:
nconvert.exe
-o c:\tmp\mini_%.jpg -out jpeg -ratio -resize 100 d:\atest\*.jpg
I detected, that the first file in the source-directory (d:\atest) is not processed by nconvert if the directory contains more than one file.
If the directory contains only one File, nconvert processes this file.
Re: nconvert ignores the first file / processing directory
Post by Guest »
asi wrote:Hi,
nconvert.exe
Sorry, I forgot Operating System W2k; Newest NCONVERT version.
Jerry Riggens
First File
Post by Jerry Riggens »
If one of the ncovert gurus can't help, you can always
wrap the command with a shell/batch file that automatically
generates a bogus file for nconvert to ignore.
- jr
