Repeatedly selecting toolbar option category will increase GDI Object count.
1. Open Xnview. Count is [158]
2. F12 Open options and select toolbar category. GDI count [295]
3. Close Options using <cancel>. [231]
4. Repeat steps 2 and 3 five more times. [591]
B5: Minor: Toolbar options GDI Leak.
Solved… In TC !
• I confirm, and here with ß-5, I get :
Step 1.
Start 46 >> Options tool-bar >> 189 >> Close the tool bar >> 113
Step 2.
Start 113 >> Options tool-bar >> 257 >> Close the tool bar >> 185
Step 3.
Start 185 >> Options tool-bar >> 329 >> Close the tool bar >> 257
Step 4. Close XnView >> Restart >> 40
• This is a bug I know because we had the same in Total Commander while testing Alphas recently…
And also for the button-bars settings.
- It's pretty complicated to fix up, as far as I understood, because the fix must be valid with all OSs …
- I've sent a tip to Pierre about this, hoping he'll get it soon…
Note to other testers : The GDI Objects column is not displayed by default, you ought enable it in the Display menu of the T-Manager
