B5: Export GDI Leak.
Repeatedly opening and closing export dialog will cause GDI Object count to rise by about 12 each time.
Start>158>Open|Close>[174]Repeat>[186],[198], etc.
Accuracies elswhere
Still buggy
• Not fixed up in ß-6 for Export :
- Open 1st. : +23
- Open 2nd.: +20
- Open 3rd. : +22
- Restart, same image, no “Export” : 53…
Re: Still buggy
Really??? I have no more the GDI leaks...Clo wrote:Hello B. !
- Open 1st. : +23
- Open 2nd.: +20
- Open rd. : +22
Export only
All DLLs ?
• Yes, I did of course !
- It could be an issue with all DLLs, while the embedded resource stuff doesn't cause any leak…
- I've to retest with RC1 now…
Re: All DLLs ?
Clo, does the problem still occur with RC1?Clo wrote:- I've to retest with RC1 now…
A few now
• Hello !
• The GDI objects are increased but just a few now,
let's say as 58 when beginning a test up to 62…65 at the end with 4…5 tries.
- Closing the displayed image "to export" doesn't decrease the last number, though, but it doesn't seem important now…
G.
Re: A few now
Thank you for checking, Clo. If there is still a GDI leak it should be fixed, I think.Clo wrote:- Closing the displayed image "to export" doesn't decrease the last number, though, but it doesn't seem important now…
Re: A few now
Yes, but can't reproduce ithelmut wrote:Thank you for checking, Clo. If there is still a GDI leak it should be fixed, I think.Clo wrote:- Closing the displayed image "to export" doesn't decrease the last number, though, but it doesn't seem important now…
