In Beta 5 (original message here): dragging files over a collapsed Folder/Favourite/Category should expand it automatically.
(without changing focus and displayed files in filelist)
Dragging file over Folder/Favorite/Category should expand it
Olivier_G
Re: Dragging file over Folder/Favorite/Category should expan
Currently you have it on folder tree, but only if you drag&drop on the '+', not full item. If you think that it's better to use the item rectangle, no problemOlivier_G wrote:In Beta 5 (original message here): dragging files over a collapsed Folder/Favourite/Category should expand it automatically.
Olivier_G
Wow... right! I didn't find this!xnview wrote:Currently you have it on folder tree, but only if you drag&drop on the '+', not full item. If you think that it's better to use the item rectangle, no problem
Yes, I think it would be much better to use the item rectangle (or ideal: '+' & Bitmap & Item rectangle, if possible).
Olivier
Olivier_G
Implemented in Beta 6!Olivier_G wrote:or ideal: '+' & Bitmap & Item rectangle, if possible.
Olivier
