Add an automatic “Batch capture”…
:) Hello !
• I couln't find anything about this using the Search, so I post this request in the way I would like such a feature.
- Below is the fake I drew to illustrate the request, I hope it's self-explanatory :
———— Image
• Whether some extra-option¦s w¦s¦hould be needed (or an info) there is remaining room in the “Options” section.
• Currently, when one needs this feature, one is bound to use a specialized software.
- Unfortunately, only a very few ones are able to do so, and are not free of charge :|
• Feedback welcome !
:mrgreen: Kind regards,
Note : BTW, the current “Capture Setting” box has some hitches about the section-frames painting…
ouistiti
Post by ouistiti »
:arrow: Pierre
:) Hi !
Nice ! I need often such a feature…
- True ! I found out only one, and rather overpriced (US$39…) :(
- It should be nice to get this in a next version, so XnView should score marks with regard to some competitor which has not this yet ;)
- Adding this to your endless “ToDo” list should be a nice X-Mas present :D
Friendly
Paul
1,77245385090552... •
Other way…
:) Hello Paul !
• Thank you for your interest !
• At the very outside, this function could be built as a standalone one, linked to the programme. I mean :
- Either as a built-in function, but having its separate dialogue and menu entry,
- Or as an EXE¦DLL working from the usual dialogue modified like above.
- That should avoid to add fat to the main EXE… ;)
:mrgreen: Friendly,
marsh
Post by marsh »
I was also looking for this a few months ago, but was too lazy to try other software. :D
So, built-in ?
:) Hi B. !
• … and you saved $ 39 ! Image
• So, would you like this as built-in (or as a plugin working like said above) ?
:mrgreen: FR
marsh
Re: So, built-in ?
Post by marsh »
Clo wrote::) Hi B. !
:mrgreen: FR
Built in: [x]Desktop [x]Delay [x]Multiple Capture [x]Save Directory...
But, such a feature might not be noticed without GUI adornment.
We miss…
:) Well, but we miss still a pre-defined number of captures and an “end-sound” for such an automatic stop…
• And there is a big hitch : Multiple capture works only with a key strike currently !
- With Delay, it's greyed !
• Indeed I would prefer a GUI…
:mrgreen: FR
