A lot of info is getting put (incorrectly?) on the browse-mode status bar and not updated at all.
Repro:
1. Find a folder with files click and look at info; the size is all it shows.
2. View or fullscreen a file, and exit.
3. Now, when you click on any file, the size updates, but also includes the name and info on the file you viewed! Not the current one clicked on. (The dimensions, at least, are very handy and ought to be included with the size.)
4. Change to another folder. Same info except a blank filename, until you view another file.
B5: File info in browser status broken
Re: B5: File info in browser status broken
Can't reproduce it, (1) if you click on a file you have only file size??foxyshadis wrote:A lot of info is getting put (incorrectly?) on the browse-mode status bar and not updated at all.
Repro:
Olivier_G
foxyshadis
Olivier_G
foxyshadis
Olivier_G
Confirmed: last opened image (browser's fullscreen) won't display its name in status bar.foxyshadis wrote:Minor bug left: If you open an image in fullscreen then close, it only shows the name until you open another file.
-> Confirmed.
I think this should be corrected. Not necessarily for 1.90 if important changes are required, though...foxyshadis wrote:it still doesn't show anything but size and filename without preview.
Olivier
