icc profiles in tiff files
sergo
Post by sergo »
sorry but problem with icc profiles in tiffs still exist in beta 5
link to old post: http://newsgroup.xnview.com/viewtopic.php?t=10971
XnView 1.90 <x>
Olivier_G
Post by Olivier_G »
I can't confirm: Tiffs with AdobeRGB embedded profiles work fine for me (Beta 5):
- they look different with/without option.
- JPEG and TIFF versions look exactly the same (and as they should be).
-> moved to 'New' (waiting for more confirmation).
Olivier
sergo
Post by sergo »
I've found the problem - if tiff file is 8bit-per-channel image and HAS ONE alpha channel it's icc looks incorrect.
if tiff file is 8bit-per-channel image and hasn't alpha channel or has two additional channels it's icc works well in xnview.
if tiff file is 16bit-per-channel image icc doesn't work at all in xnview.
here is link to archive with some images.
I can send you these files by email, if it is more convenient.
http://www.filefactory.com/file/930851
press - Download for free with FileFactory Basic and then - Click here to begin your download.
sergo wrote:I've found the problem - if tiff file is 8bit image and HAS ONE alpha channel it's icc looks incorrect.
if tiff file is 8bit image in hasn't alpha channel or has two additional channels it's icc works well in xnview.
if tiff file is 16bit image icc doesn't work at all.
Ok, i check...
Olivier_G
Post by Olivier_G »
sergo wrote:if tiff file is 8bit-per-channel image and hasn't alpha channel it's icc works well in xnview.
I confirm both those situations with my own images... :(
Olivier
sergo
Post by sergo »
sergo wrote:if tiff file is 8bit-per-channel image and HAS ONE alpha channel it's icc looks incorrect.
problem with icc in 8bit-per-channel tiff files is fixed. I think so:)
but i've found another problem with icc http://newsgroup.xnview.com/viewtopic.php?p=41853#41853
sergo
Post by sergo »
These problems are solved in RC1.
Olivier_G
Post by Olivier_G »
sergo wrote:if tiff file is 16bit-per-channel image icc doesn't work at all in xnview.
This is still not fixed in 1.90 RC2 -> Confirmed.
Olivier
Yes, currently i can't fix it for 16bits...
Olivier_G
Post by Olivier_G »
xnview wrote:Yes, currently i can't fix it for 16bits...
-> postponed.
Olivier
goddert
Post by goddert »
postponed
Sorry, I couldn't find any other related topic. Is this still valid? Currently Xnview doesn't display correctly 16bit-tiff-files with embedded icc-profiles. I'm using PS and Lightroom for photography and both use 16bit-tiff with Prophoto.
Thanks
goddert wrote:
postponed
Yes, currently ICC works only on 8bits files
