b5: Crash, when opening another image from explorer
FlorianH
Post by FlorianH »
options to reproduce this crash:
- only one instance
- start file in fullscreen browser mode
1) xnview is open (doesn't depend on mode, e.g. browser or fullscreen browser)
2) new image is opened in windows explorer
-> windows bug report wizard appears for xnview, but existing xnview session still works
Olivier_G
Post by Olivier_G »
Confirmed: XnView already opened, if I double-click an image associated with XnView in File Manager -> another session of XnView is started and immediately crash. :bugconfirmed:
Olivier
Olivier_G wrote:Confirmed: XnView already opened, if I double-click an image associated with XnView in File Manager -> another session of XnView is started and immediately crash. :bugconfirmed:
I can't reproduce this bug, the picture is opened correctly in first instance of xnview...
FlorianH
Post by FlorianH »
xnview wrote:I can't reproduce this bug, the picture is opened correctly in first instance of xnview...
Pierre, i assume, that you have several versions of XnView on your testing machine... If only b5 is installed, it can be reproduced 100%. If you have several versions installed, be sure, that the file type is realy associated with XnView b5 (i had to delete the file association in explorer and recreate it to reproduce the bug on the machine with several XnView installations).
BTW: my systems are XP Prof. SP2
Really? Yes, i have good association... :-(
Confirmed. The problem only occurs with both options set appropriately.
Tools > Options > General > Operations
- Only one Instance
- Mode when starting with a file: Fullscreen - Browser
Olivier_G
Post by Olivier_G »
Fixed in Beta 6.
Olivier
