Still BGs for file types…
:arrow: Pierre
:) Hello !
You wrote
Houps, ok. ColorFilter is for text color, not background...
• I just checked in ß-6, we have still the backgrounds as colours by file-types, not the texts… :?
• Checking the INI, I see that we have now also the BG and the colours, but the default colour values being the same (I didn't rebuilt the whole INI !) on the screen we might read nothing…
BColorFilter26=jp2, 237 237 202
ColorFilter1=jpeg, 237 237 202
- I see still the BGs and a black font for all.
- Please, indicate which handling is needed to use the fonts colours and the single BG for all…
- In the meantime, I continue to test this…
:mrgreen: KR
V 1.90 B6
Re: Still BGs for file types…
Clo wrote: - Please, indicate which handling is needed to use the fonts colours and the single BG for all…
Remove all BColorFilter
Not the trick
:arrow: Pierre
:) Hi !
:( That doesn't the trick, since the programme rewrites them immediately,
with the old default colours, like we saw out the forum…
• I had to rename the ColorFilter1…9 into 01 …09 like you said, and then I get the colours for these entries for text.
• One may set an individual custom BG for each type, but I couldn't get the single common BG for all.
- This issue is pending.
- Also the question : May we add types, or is the bunch limited to the original INI entries amount ?
EDIT : According to my next tests, the answer is NO :(
- Limited up to 26 file-types…
:mrgreen: KR
Re: Not the trick
Clo wrote:• One may set an individual custom BG for each type, but I couldn't get the single common BG for all.
You have the option in option/File list/Misc
The snag is---
:) Hello !
• It doesn't take precedence over the individual BGs, and since one can't suppress them, they are displayed still…
- Only the files having no colour¦BG by type have this “single” BG…
• That seems unsolvable as long as the individual BGs can't be really disabled and NOT rebuilt endlessly…
:mrgreen: KR
Re: The snag is---
Clo wrote::) Hello !
• I doesn't take precedence on the individual BGs, and since one can't suppress them, they are displayed still…
Currently the only is to change all BColorFilter
ON¦OFF
:arrow: Pierre
:) Hello !
• Indeed, and sometimes this could be interesting…
- But it should be nice to get an entry able simply to turn all the BColorFilter ON¦OF as one go, let's say like :
SwitchB_Filters = Flag
Image0 –> OFF (default)
Image1 –> ON
• Nice to have this for the final release if possible, please… 8)
:mrgreen: KR
