Button "delete"
aiglobulles
Button "delete"
Post by aiglobulles »
I'm french so excuse me if my level in english is not very good ;)
I return to use xn view a few time ago. It is better than before and I just think that it could be practical to have a "delete" bouton in the bouton menu bar.
Actually, I have to make a right click and select "delete" to delete a picture... it could be easier with a special button to make that.
Lot of thanks for the autor for this very good software.
regards
aiglobulles from france
Un site photo sympa: http://photobook-asso.net
foxyshadis
Post by foxyshadis »
In options, there's a toolbar screen. Select view or browser depending on which you want it in. You can click append, find cmd_Delete in the list, and add an icon if the skin doesn't have one. Then you have a delete button. =D
foxyshadis wrote:In options, there's a toolbar screen. Select view or browser depending on which you want it in. You can click append, find cmd_Delete in the list, and add an icon if the skin doesn't have one. Then you have a delete button. =D
In next release not current!!
