Season's bug ?
Season's bug ?
:) Hello !
• An oddness or :bug: ?
1. Copy any image in the Clipboard…
2. Import Clipboard
3. Ask for “Save as…”. On the dialogue tick the box Keep original date¦time attributes
4. Save the NEW file in a folder you notice alright…
5. Go to see your new file in a file-manager :
- Here today December, 23rd. 2006, the file is set as November, 8th. 2003 !
- In previous versions, I even noticed such new files set as 1980…Good luck to found out the files then !
• IMHO, when saving a new file made with Import Clipboard, the above-mentioned option might be ignored !
- Currently, I'm bound to disable it permanently because I create a lot of screen shots, and need to get the right date¦time.
:mrgreen: KR
marsh
Re: Season's bug ?
Post by marsh »
Clo wrote: • An oddnes or :bug: ?
Greetings,
It is both. And a very curious one:
I got the years 28,935 and 1617 and the file original in other cases!!
And a twist: If you close file before importing clipboard, it behaves differently.
---> Confirmed
marsh
Post by marsh »
Saving clipboard uses current date and time now. It is fixed for me.
No more fancy…
:) Hello B. !
• I can confirm : Fixed up here too !
:mrgreen: FR
