When change options and close XnView - it's crashing without saving changes in ini file. =(
But this bug was since B4 or B3..
B6: Crash on close, not saving ini
Re: B6: Crash on close, not saving ini
Which option do you change?Arlekin wrote:When change options and close XnView - it's crashing without saving changes in ini file. =(
Arlekin
foxyshadis
It's not a bug since it's impossible to properly save an ini after a crash (you can save something, but you run the risk of saving corrupted data). Hopefully a future version will save the ini when you close the options or make other big config changes.TsunamiZ wrote:well when xnview crashes, it doesn't save ini. is that a bug?
Arlekin
