Add text
DOS386
Add text
Post by DOS386 »
I tried to add text into images with NC and there seem to be problems.
Probably I am doing something wrong but maybe there are also bugs. :bug:
"-text string" "-addtext"
"text" or "addtext" ??? XNview generates "addtext" and NC does NOT
recognize it.
The text itself must be quoted ?
How to set position, rotation, colours, font and size etc. ? I tried something
but it gets mostly ignored.
Could you provide a more detailed manual, as a text file bundled with
NCONVERT, not only in this forum ? The texts in latest NCONVERT package
are outdated and don't provide too much info on syntax and examples.
Fonts: What fonts are available, or where do they come from ?
Re: Add text
NTOSKRNL_VXE wrote:I tried to add text into images with NC and there seem to be problems.
recognize it.
You can use -text_font arial -text_pos 0 0 -text "a text"
DOS386
Bug ?
Post by DOS386 »
Thanks, but this example does NOT work. :bug:
The "-text_font" breaks the thing and I get 6 errors about file not found,
affectig files "100" "100" "-text" "a text" "-out" "png", resulting in
a dummy "conversion" of x.bmp into identical x.bmp.
Removing "-text_font" helps. Also, "-text_rotation" seems to work, as long
as no "-text_font" is present.
Re: Bug ?
Sorry there is font size, too. So -text_font arial 10
All parameters:
-text_font arial 10 -text_pos 0 0 -text "Sample text"
