Is there a way to do this? To make xnview "resample" the image so that it doesn't look so "sharp"?
I like to see pics of a game i play in windowed mode and other image viewers "resample" the pic so I can read the text on it (it makes it a bit blurry but you can make out what the text says)... but with xnview i can't find the feature to turn this on, so the text in the pic looks really sharp and skewed.
I apologize if i don't use the correct terms, I'm not too familiar with the image editing / viewing lingo.
Thanks.
auto-resampling when viewing (fitting image to window)
Re: auto-resampling when viewing (fitting image to window)
You have View/High zoom qualitytet wrote:Is there a way to do this? To make xnview "resample" the image so that it doesn't look so "sharp"?
Thanks.
