Question: Slide Show Small Images
Post by Guest »
first of all, this is the best graphic program I've ever worked with and want to thank the developers for sharing it with us.
my question is on the latest version, the slide show enlarges all files, compromising the quality of smaller pictures
I have played with the settings but have yet to find the setting that prevents this and allows the slide show to display pictures in their true size
can someone please point me in the right direction
and thanks again
Try this…
:) Hello !
• Please, try this :
- Tools Menu >> Slide Show >> More options button >> Remove the nick of the box Strech small pictures
- Eventually, also the second box below Strech small videos
• Normally, the small images might not be blown-up anymore…
:mrgreen: Kind regards,
Post by Guest »
thank you for the response. yes, I tried that and all other options I could imagine would do the trick but no luck. and after looking into it further, it is not just small images but is seems the majority of images the slide show stretches... hopefully there is a fix to this..
thanks again
Anonymous wrote:thank you for the response. yes, I tried that and all other options I could imagine would do the trick but no luck. and after looking into it further, it is not just small images but is seems the majority of images the slide show stretches... hopefully there is a fix to this..
thanks again
Small picture are fitted to the screen even if the option is disabled??
