There are often severel MPEG-Codecs on a system, like Cyberlink, Intervideo. VLC etc. Some Codecs gives better Playback-Quality. The Cyberlink Codec can play HDTV-MPEG2 Video on a P4 2,8 GHz without lost frames. Is it possible to tell xnview, which codec it should use to play the clip ?
Xnview is my favorite program to view pictures and videoclips. Best wishes for the new year to the developers and the community.
In the beta6, there are no thumbnails for vidoeclips, xnview 1.82.4 works correct...
Select mpeg-codec for MPG-Playback
Re: Select mpeg-codec for MPG-Playback
No sorryTim wrote:There are often severel MPEG-Codecs on a system, like Cyberlink, Intervideo. VLC etc. Some Codecs gives better Playback-Quality. The Cyberlink Codec can play HDTV-MPEG2 Video on a P4 2,8 GHz without lost frames. Is it possible to tell xnview, which codec it should use to play the clip ?
No thumbs for movies files??? I have no problem, could you post in the good topic, please?Xnview is my favorite program to view pictures and videoclips. Best wishes for the new year to the developers and the community.
