Changing write protection does not work
When setting or unsetting the write protection in the properties dialog, the write protection will not be changed. :bug:
1. In XnView Browser select a file
2. Open the properties (Edit > Properties)
3. Change the write protections state (check or uncheck).
4. Close the dialog
5. Reopen the properties dialog
-> State of write protection has not been changed :bug:
The problem is in 1.82.4 and 1.90 Beta6.
And the opposite
• Hi !
- Confirmed, and also the opposite when one adds any other attribute…
- In fact, the function Change attributes is totally broken in XnView.
:mrgreen: G.
Re: And the opposite
Clo wrote:- In fact, the function Change attributes is totally broken in XnView.
Yes. Thank you for checking and confirming.
marsh
Post by marsh »
It works great in Win2k though.
marsh wrote:It works great in Win2k though.
Strange. Looks like a Windows XP specific bug. I have just checked the priviledges but that's not the problem.
Hmm, there's a button Apply and OK. When pressing "Apply" the dialog closes and does apply the changes. But when pressing "OK", the dialog closes and changes are not applied. :o
So the problem are the buttons OK and Apply. Correct is:
- OK: Apply changes and close dialog. (Currently wrong)
- Apply: Apply changes, do no close dialog. (Currently wrong)
- Cancel: Close dialog, do not apply changes.
marsh, can you confirm my observation on Windows 2000?
No, only Apply make the changes...
xnview wrote:No, only Apply make the changes...
From my point of view this is an unexpected behaviour which should be changed & fixed.
For me it's strange, that Ok apply changes!
xnview wrote:For me it's strange, that Ok apply changes!
Have you used Windows and XnView? In those pretty common applications "OK" applies changes and closes the dialog. In XnView the following dialogs behave like this for example: Options dialog, Rename, all the effects and Adjust dialogs.
If OK closes without saving, what does Cancel do?
(Sorry for being a bit sarcastic, but I'm a bit baffled by your answer). :o
:-) Houps, yes right
