Toolbar appears briefly upon startup...
TsunamiZ
Post by TsunamiZ »
Toolbar appears briefly upon startup even though I have it set to off. It is annoying and slows down the drawing of the interface on startup. Please fix.
V1.90 B6
Olivier_G
Post by Olivier_G »
Strange: I can't confirm... although I am quite sure I saw that too before... :?
I'll check this more and report.
Olivier
Re: B6: Toolbar appears briefly upon startup...
TsunamiZ wrote:Toolbar appears briefly upon startup even though I have it set to off. It is annoying and slows down the drawing of the interface on startup. Please fix.
You start in browser mode? And toolbar is hidden in this mode?
TsunamiZ
Post by TsunamiZ »
ya, but it appears briefly before disappearing
marsh
Post by marsh »
OK. This is caused by the toolbar also being enabled in viewer mode which you probably don't use. Disable the toolbar in both places, and you should stop experiencing this.
TsunamiZ
Post by TsunamiZ »
thanks that fixed it. although it may still be something worth fixing if it's a quick fix.
