B6: Shortcut files in browser don't open files ...
TsunamiZ
Post by TsunamiZ »
Double click shortcut files in browser still don't open files. Although it opens with F3. Perhaps add shortcuts as part of 'all other files - open in associated program'?
[i have only images set to open in xnview. everything else opens in associated program. i have a shortcut to a text file which should open in notepad but it doesn't.]
Re: B6: Shortcut files in browser don't open files ...
TsunamiZ wrote:Double click shortcut files in browser still don't open files. Although it opens with F3. Perhaps add shortcuts as part of 'all other files - open in associated program'?
I have not this problem, if i dbl-clic on a shortcut, the picture is opened in fullscreen, or opened in viewer...
marsh
Post by marsh »
Correct.
Double/Click on shortcut works perfectly.
TsunamiZ, could you please check your Open action for double-click on Image files in "Tools > Options > Keyboard/Mouse". It supposed to be "Open in XnView".
TsunamiZ
Post by TsunamiZ »
i have only images set to open in xnview. everything else opens in associated program. i have a shortcut to a text file which should open in notepad but it doesn't. :?
TsunamiZ
Post by TsunamiZ »
this is still an issue and is not solved. please put it back in the bug list.
marsh
Post by marsh »
TsunamiZ wrote:this is still an issue and is not solved. please put it back in the bug list.
I cannot recreate problem.
----->New/Open
TsunamiZ
Post by TsunamiZ »
make a shortcut to a text file and try double clicking the shorcut. you'll see it doesn't open the text file at all [and i want it to open in notepad]. but the preview shows the text file. :?
marsh
Post by marsh »
TsunamiZ wrote:make a shortcut to a text file and try double clicking the shorcut. you'll see it doesn't open the text file at all [and i want it to open in notepad]. but the preview shows the text file. :?
I still don't see it. Anyone else?
TsunamiZ
Post by TsunamiZ »
this bug was in 1.82.4 as well :(
Dreamer
Post by Dreamer »
Works perfect here.
Dreamer
TsunamiZ
Post by TsunamiZ »
how can it work for you guys and not for me? i even started off with a clean .ini config. :?
Same here
—> TsunamiZ
:) Hello !
• Same behaviour here, I confirm.
- I have "Open" in Keyboard¦Mouse set to the default programme with 2-click for TXT.
- Moreover, the preview displays the text, but it uses probably the EXE-core font, I suppose still the crappy MS Sans Serif, since some upper ANSI characters are not displayed, I get black rectangles instead…
- 29 characters are missing in that bitmap font, quite inappropriate to display text in a preview :(
:mrgreen: KR
TsunamiZ wrote:i have only images set to open in xnview. everything else opens in associated program. i have a shortcut to a text file which should open in notepad but it doesn't. :?
Very strange, and with a new .ini you have always the problem...???
TsunamiZ
Post by TsunamiZ »
yup new ini :(
