'Favorites' list save location in 1.90?
TsunamiZ
Where is the 'favorites' list save location in 1.90? Does it save in the .ini file?
Still same file
• It's still saved in the same file “bookmark.ini” like formerly.
- It's located in the folder you state in the Options >> System integration >> Folder for all others files
- red “s” is a spelling mistake -
- For instance, here I've :
E:\XnVIew_190_beta\bookmark.ini
• Didn't you check the options ? You might do…
