B6: Crashes when opening / viewing .PSD files
TsunamiZ
Post by TsunamiZ »
Crashes when opening / viewing .PSD files in browser to fullscreen. Crashes in the browser and fullscreen modes. .PSD files are 2-3.5 MB, multilayers, 3200x2400 px, and made with Photoshop CS2. Doesn't always happen but does happen unpredictably. Please fix.
[1.82.4 didn't have this crash.]
Re: B6: Crashes when opening .PSD files
TsunamiZ wrote:Crashes when opening .PSD files in browser to fullscreen. Crashes in the browser. .PSD files are 2-3.5 MB, multilayers, 3200x2400 px, and made with Photoshop CS2. Doesn't always happen but does happen unpredictably. Please fix.
Could you send the file, please?
TsunamiZ
Post by TsunamiZ »
http://www.sendspace.com/file/k1qds3
make multiple copies of that .psd and quickly switch between viewing them in browser/fullscreen mode. when the crash occurs is unpredictable.
TsunamiZ
Post by TsunamiZ »
im not sure if this has to do with .psd files in particular or just several MB files, but it doesn't happen to 500KB .JPG files.
marsh
Post by marsh »
Confirmed with downloaded samples. I'm not entirely certain, but I think this occurs only when ICC is turned off.
TsunamiZ
Post by TsunamiZ »
the .psd doesn't have icc. and xnview has icc off.
TsunamiZ
Post by TsunamiZ »
the crash also happens quite often when switching [next/prev] the .psd images in fullscreen mode :?
marsh
Post by marsh »
TsunamiZ wrote:the crash also happens quite often when switching [next/prev] the .psd images in fullscreen mode :?
Convert those same images to JPG and you will see an identical crash. It also occurs when only highlighting them in browser.
TsunamiZ
Post by TsunamiZ »
could this crash possibly be due to resizing such hi-res images upon view?
You have many copies of this converted files in jpeg, you click on a file and crash????
TsunamiZ
Post by TsunamiZ »
after i convert the .psd's into .jpg, theyre only about 150-200 KB each, and they don't crash xnview :|
TsunamiZ wrote:after i convert the .psd's into .jpg, theyre only about 150-200 KB each, and they don't crash xnview :|
You have the crash only in fullscreen(browser) and switch between them quickly? Even with a fresh ini?
TsunamiZ
Post by TsunamiZ »
fresh ini, crashes in fullscreen[browser]--not fullscreen[viewer] or viewer
Ok, i've found it, it's a problem in IPTC!!
TsunamiZ
Post by TsunamiZ »
great :D thanks
