background color
Cnuut
background color
Post by Cnuut »
I would like an option to change the bakground color in the viewer window.
I mean so there is a possibility to directly change to black - grey - white.
I hope you understand my request :D
marsh
Post by marsh »
I'm not sure I understand. v.1.82.4 has option View>Background Color
In theory…
—> Cnuut
:) Hello, welcome aboard !
• If I got you alright, you'ld wish to change the background-colour in the Viewer “on the spot”,
maybe to highlight better the current displayed image ?
• I guess that -in theory- this is not impossible, but many users would think that the game isn't worth the candle…
• Anyway, it should need a menu entry (or an extra-button) and a dialogue opened from it,
in order to get an Apply button to change in the INI and reload it…
• Moreover, the pre-defined colours you quote couldn't do the trick for everybody (and I) !
So, on that dialogue, they might be configurable. Complicated…
• I'm not against, but there are important changes to realize before, IMHO.
- So, a “Nice to have” for a (very) far version… :P
:mrgreen: Kind regards,
Cnuut
Post by Cnuut »
Yepp Clo you got it.
I understand that theres some long hours of coding to make it happen, but as you said it would be nice to have :)
Simpler=sooner
—> Cnuut
:) Hello !
• I thougt to get a simpler feature, at least to set it…
• Whether we could obtain an internal command for each BG colour, so then the thingy becomes more feasible :
• This could be a section somewhere in the Options, or even a non-modal box, like i.e. the “Grid Settings” one…
• Each command could be used even now with an extra-button in the tool-bar,
and also later as an extra-entry in a menu with future menus as text
- It might be able to change the BG in the INI and to reload it as one go…
- What do you think ?
:mrgreen: KR
Cnuut
Post by Cnuut »
Go for it! :)
I got the idea from a "photosite", they´ve got the function when viewing pics, check it out:
http://www.fotosidan.se/
quicklink to a pic:
http://www.fotosidan.se/gallery/viewlar ... get=_blank
Nice !
—> Cnuut
:) Good morning,
• Ah ! Really nice with these three small buttons !
- So, we could have similar buttons, but only on the tool-bar…
- I'll draw samples (the extra-icons don't come with the skins currently, but I've some personal skins I can patch at will…).
- Light - Medium (default) and Dark BGs.
• Finally, something to put on the back burner, hoping the Author'll express his opinion Image
:mrgreen: KR
Samples---
:) Hello !
• How it could look with extra-icons for a small (distributed) skin of mine :
————Image
:mrgreen: KR
Needed now…
:arrow: Pierre
:) Hello !
• This proposal becomes more needed now, since we have some improvements at the transparency display (icons i.e.)
• Hence, what about to plan it for a medium version, let's say… 1.9.5 or so ?
• Personally, I would be rather in favour of a small non-modal window to place the settings I showed above,
not a very big deal, finally…
:mrgreen: KR
10 months---
—> Pierre
:) Hello !
{ More than ten months later…}
    * BUMP ! *
:mrgreen: KR
ouistiti
Post by ouistiti »
:arrow: Clo
If it should be a cow elephant on a gestation period, only eleven months remaining to wait… :o
Friendly
Paul
1,77245385090552...
