Scan selected files with anti-virus in right click menu?
TsunamiZ
Post by TsunamiZ »
Is it possible to scan selected files with anti-virus option in right click menu like in Windows Explorer? I use Kaspersky Anti-Virus 6.
marsh
Re: Scan selected files with anti-virus in right click menu?
Post by marsh »
TsunamiZ wrote:Is it possible to scan selected files with anti-virus option in right click menu like in Windows Explorer? I use Kaspersky Anti-Virus 6.
You can try to test "Open With" function. I don't know if the required commands/switches are possible in INI file.
Dreamer
Post by Dreamer »
You can use ctrl+right mouse click for standard windows context menu, scan should be there then - only in the new (beta) version.
Dreamer
But…
—> Dreamer
:) Hello !
• Yes, but it works only on a selected thumb nail or on the selected row of a file with other display-mode in the browser.
- It does not work in the Viewer…
• Aside :
- Randomly, I got unwanted XnView closures while testing Viewer <— —> Browser —> Change the display-mode… :?
- No crash, no message, only closed…
:mrgreen: KR
