Batch Rename Selection bug
ckit
Post by ckit »
After renaming 15 files with Batch Rename, the first 4 files are unselected while the remaining files are selected.
All of the original files should be selected!
V 1.90 B6
Dreamer
Post by Dreamer »
Can't confirm.
Dreamer
Can't confirm too.
I'm not quite sure whether this is related or not:
With XnView default settings (xnview.ini previously removed):
In a folder with multiple files I batch rename 6 files from blubber## to blubber###. After renaming, the first file in the folder is selected and none of the renamed files.
