Rotate is "greyed out"
DOS386
Post by DOS386 »
When using B6, seems quite stable, but bug :bug: occured:
- "Rotate" was "greyed out" - No way to rotate !!! :-(
- Loading other image -> No effect
- Reboot: fixed
Unfortunately, can't provide a secure way how to reproduce this bug. :-(
Are there situations when "Rotate" is supposed to be greyed out legally ?
V 1.90 B6
Re: B6: [BUG] Rotate is "greyed out"
NTOSKRNL_VXE wrote:When using B6, seems quite stable, but bug :bug: occured:
- Reboot: fixed
Rotate in view mode??
DOS386
Possible bug
Post by DOS386 »
YES. "Image" -> "Rotate"
The "Rotate" was greyed out and next submenu did not come up :bug:
Multi…
:) Hello !
• “Rotate” could be greyed out if the image is a multi-page¦multi-frame type…
:mrgreen: KR
Re: Possible bug
Can't reproduce, do you reproduce it always?
DOS386
reproduce bug
Post by DOS386 »
NO. :-( As written before:
1 time and after reboot never again.
When investigating, other bug occured: image disappeared after
rotating. "undo" brought it back. Saved as PNG, rebooted, retried:
no problem. One-time bug again. :-(
If 1.90 final is ready and nobody confirms these bugs ... move to "closed" :-(
NTOSKRNL_VXE, could you please check/observe the problem with XnView 1.90 RC1?
Re: Multi…
Clo wrote:• “Rotate” could be greyed out if the image is a multi-page¦multi-frame type…
Right, or an animated GIF (which is a special type of multi-page image).
DOS386
Rotate bugs
Post by DOS386 »
Well, it was neither multi-page nor animated. Just an ordinary, rather big
(1500 ... 4000 pixels per dimension), image, and both bugs occured after
a large amount of edits.
OK, I'll upgrade to RC1 or RC2 ... but since there is no safe way to
reproduce there is also no safe way to verify a fix :-(
Re: Rotate bugs
NTOSKRNL_VXE wrote:OK, I'll upgrade to RC1 or RC2 ... but since there is no safe way to
Very true. :-|
Re: Multi…
Yes, but difficult... When you click on a file, i don't load it to see if it's a multi page or animated file...
