Hi everybody,
I just download the program and want to be able to display .wbz files but there is not such extension declared on the program and in the website it is listed but not available at all. What can I do?
I really appreciate all the help you can share. Thx.
cernunnos
How to configure XnView for display WBZ files?
Re: How to configure XnView for display WBZ files?
Just some info for all those who have this same problem that I just find a way to fix.cernunnos wrote:Hi everybody,
cernunnos
on the menu tools\options\general\start(inicio) activate the box "view all formats" and click OK. reinitialize the program and you'll find that the problem was fix automatically!!
Nqw I'm able not just to see all those .wbz files without any problem but also I was able to convert them to .jpg format!. It's that easy!
Probably it is a wise move to set for all the new downloads this box as checked. What do you think administrators?
Thx anyway and have a great day you all!!
cernunnos
I vote for this, implicitly checked!cernunnos wrote: Probably it is a wise move to set for all the new downloads this box as checked. What do you think administrators?
Thanks for your help, Cernunnos, I have the same situation and resolved...
