Convert to Black&White
peter6010
Post by peter6010 »
Hi, I would like to ask if it is possible to converting images to black&white (only these two colors (1BPP), no greyscale) with nconvert. I did not found the parameter for that.
Thanks.
P.
Re: Convert to Black&White
peter6010 wrote:Hi, I would like to ask if it is possible to converting images to black&white (only these two colors (1BPP), no greyscale) with nconvert. I did not found the parameter for that.
Thanks.
P.
Yes with -binary
peter6010
Post by peter6010 »
Thanks.
P.
Yes with -binary
Thank you very much...it works PERFEKTLY ! :D
