1. Select 2 files in browser. The first a PNG. The second a JPG with embedded thumbnail.
2. Press <rotate 270> button in browser's toolbar.
3. *The embedded rotate icon disappears on JPG. The thumbnail icon will be visible using v.1.82.4, but not v.1.9rc1 after rotating JPG.
4. Press <rotate 90> button again.
5. *Status bar is frozen and thumbnail is not updated until list is refreshed using <ctrl r>.
----Edit---
Only the progress indicator not finishing on status bar is a problem to look out for. I cannot recreate it anymore...
Step #3 was my error. It is normal with a new thumbnail appearance option.
RC1: stuck progress indicator.
marsh
Re: RC1: stuck progress indicator. disappearing icon.
Could you send the jpeg file used?marsh wrote:1. Select 2 files in browser. The first a PNG. The second a JPG with embedded thumbnail.
marsh
marsh
marsh
I think this duplicate of topic below. --->Closed
B6: Rotation in browser need manual refresh
