B6: Jibberish title bar text (“You must restart XnView.”)
The message box which pops up and tells you to restart XnView when you tick or un-tick the Use XP style menus checkbox (Tools » Options » Interface » Windows) has jibberish text in its title bar (“€ô□”/“êRàwù□□□”) on my Windows 2000 installation.
Hmm, on Windows XP there is no title at all. I guess you are refering to RC1, not B6.
No no, this occurs in Beta 6.
I just downloaded RC1 and have yet to install/configurate it.
marsh
Re: B6: Jibberish title bar text (“You must restart XnView.”
Post by marsh »
XnTriq wrote:The message box which pops up and tells you to restart XnView when you tick or un-tick the Use XP style menus checkbox (Tools » Options » Interface » Windows) has jibberish text in its title bar (“€ô□”/“êRàwù□□□”) on my Windows 2000 installation.
Is there a common word for those square characters? I've been calling them a half dozen different names, some bad.
foxyshadis
Post by foxyshadis »
"Missing glyph spacer" would be the official one, since it's the character windows inserts for any character not in the font. I don't know what'd be a great easy name.
XnTriq wrote:No no, this occurs in Beta 6.
Do you have it with RC1?
No titje ---
—> marsh
:) Hello B. !
• Personally, I call this «craps» ! Image
• I checked : Here under XP-Pro SP1 I have not any title… All is OK.
:mrgreen: FR
Jibberish chars in B6 (Confirmed), but empty titlebar in RC1 on Windows XP. Looks alright to me.
XnTriq, do you confirm that this is resolved in RC1?
Fixed in RC1 8)
XnTriq wrote:Fixed in RC1 8)
Good. Thank you for your feedback, XnTriq.
-> Closed/Solved
