RC1 Crash with PCX histogram
Nosh
Post by Nosh »
When viewing a "pcx" file and then hitting "histogram" I get an application error at 0x0024c93b.
Regards, Norbert
Re: RC1 Crash with PCX histogram
Nosh wrote:When viewing a "pcx" file and then hitting "histogram" I get an application error at 0x0024c93b.
Regards, Norbert
Ok, i'll check
PCX OK
:) Hello !
• I cannot confirm, the histogram works OK here with PCX (from Corel 3.0)
• "RLE Compression" is ON here for this format, though it's only a reading supposed issue…
:mrgreen: KR
Nosh
Re: PCX OK
Post by Nosh »
Clo wrote:I cannot confirm, the histogram works OK here with PCX (from Corel 3.0)
It's not with all pcx files, I have emailed one to xnview.
Regards, Norbert
PS: Are you the same Clo from ghisler forum? ;-)
Same
—> Nosh
:) Hello !
PS: Are you the same Clo from ghisler forum? ;)
Absolutely ! One and indivisible ! :D
:mrgreen: KR
Nosh
Post by Nosh »
Not fixed in RC2.
Nosh wrote:Not fixed in RC2.
Strange, has been fixed, could you send it again, please?
Nosh
Post by Nosh »
I browse in xnview to the directory containing the pcx files. Then select a file, the pcx file is shown. When I now click the histogram tab in the lower right window either xnview crashes or a new xnview starts.
I'll send you all pcx files of that type that I have.
Nosh wrote:I browse in xnview to the directory containing the pcx files. Then select a file, the pcx file is shown. When I now click the histogram tab in the lower right window either xnview crashes or a new xnview starts.
I've sent you a version to check...
Nosh
Post by Nosh »
Thank you, the second version fixes the problem.
