Tree pane text and background custom color option?
TsunamiZ
How about add custom color option for tree pane text and background? This will allow tree pane text and background colors to be consistent with the other color customizable panes. Tree pane is currently the only pane that doesn't have custom color options.
REQUESTED !
• Why don't you use the Search and support the EXISTING THREADS instead of create duplicates ?
Re: REQUESTED !
@TsunamiZ: Again: This is the testing section of XnView 1.90. Version 1.90 is close to finishing and no enhancement suggestions will make it into the 1.90. Please place suggestions in the group "Suggestion".Clo wrote:• Why don't you use the Search and support the EXISTING THREADS instead of create duplicates ?![]()
-> Postponed.
<Moderator's note: This topic is likely to be a duplicate, please add new posts in the similar topic.>
-> Closed.
-> Closed.
