I'm using Acrobat 7 as only printer in my system. When I print a file the Acrobat dialog showing the print status opens but then XnView freezes and nothing happens.
When I open "Printer" tab in print-dialog, click on "Configuration" and just click OK and print the everything works fine.
In beta 9 I got a dialog telling tme that XnView tried to use some non-existing .joboptions file for the printjob instead of the default one set in Acrobat.
Please try to get this fix in 1.9 final, it's hell annoying when you have to print lots of images.
RC1: print bug with Acrobat 7
Re: RC1: print bug with Acrobat 7
And no problem with 1.82.4??aQe-YWl4 wrote:I'm using Acrobat 7 as only printer in my system. When I print a file the Acrobat dialog showing the print status opens but then XnView freezes and nothing happens.
aQe-YWl4
aQe-YWl4
Works fine with CuteWriter.
Adobe offers a 30 day trial of Acrobat 8: http://www.adobe.com/products/acrobatpro/tryout.html
In the meantime I went back to beta 6 to get you a screenshot of the error message I'm getting when XnView tries to use the wrong config file: http://img145.imageshack.us/img145/8136 ... agess3.png
It should be "Standard.joboptions" insteads and as said no other app has similar problems.
Ok, i'll try with Acrobat 8, you use Xp? admin account?aQe-YWl4 wrote:Works fine with CuteWriter.
aQe-YWl4
aQe-YWl4
Strange, i have no problem, i'll try again...aQe-YWl4 wrote:This is still broken in RC2! The error message doesn't appear anymore, but I'm not asked for where to create the file and XnView freezes while printing. If I open the printer config dialog first it works.
So it seems you fixed only a part of the problem.
Ok, could you send me an email to send you a test version?aQe-YWl4 wrote:This is still broken in RC2! The error message doesn't appear anymore, but I'm not asked for where to create the file and XnView freezes while printing. If I open the printer config dialog first it works.
